ok guys i have a few questions...
last summer I was riding this thing, while shifting something broke...
I got off, and the shift rod that comes out of the case snaped off flush with the case??? what would cause this to happen? it wasnt a rock either cause it happened in my driveway.
so i got that fixed and runs good. but I had the clutch screw turned in so it wouldnt slip so much.. it went great this way. after i got it fixed it seemed the machanic i took it to left it a little looser. why would he do this? is there a limit on how much you can adjust?
and i was wondering is there any springs in the clutch mechanism that you could replace with stronger ones so it would raise the engagement like they do on artic cat 4 wheelers?
and what else can i do to the engine on this thing to get a little more out of her???
thanks, Garrett!
---you wont float the valves---You will run out of steam long before that happens.
