i personally wouldnt run that basket even if you cant physically feel anything wrong. that basket is somewhat balanced from the factory, when a tang gets broken off the balnce is off and now even though you cant feel it, it is off and its putting wear on the clutch hub bearing(s) and is probably putting even more stress on the tangs around that broken one to take up the slack of that one being gone, and, whatever caused that one to break probably affected some of the other ones too, even if it is old age and stress cracks. chances are someday it will grenade and you will lose a case half or worse.just find a good used basket and do it right.
