This is a OEM cylinder from an 84 KX 250 dirtbike. It will bolt onto your 84/85 Tecate trike to give a drastic hp increase due to the better porting. You need to use the KX piston and all the Tecate small parts will work like circlips and such. Stock Tecate head will work with the KX cylinder as well.
***If you buy this do not hone it!!! It is Nikisel plated and all you need do is clean it, oil the cylinder wall and install with new KX rings.***
A steal for such a hard part to find. Happy bidding![]()
http://cgi.ebay.com/ebaymotors/84-Ka...QQcmdZViewItem
