Thread: Fix oil Leak?
    Mudder F er is offline At The Back Of The Pack Arm chair racerFirst time rider
    Miami, FL.
    151
    Fix oil Leak?
    Whats the best way to fix an oil leak I have on the bottom of my engine? Whats the best product to use ( JB Weld, gasket, silicone, etc) Thanks
    Mudder Fu@#er
    85 Auto 200X
    81 185s
    Have you figured out what is causing the leak?
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    if it is laeaking at one of the side covers, from a gasket leak, just see if the gasket is still good, clean it up and clean the surface of the engine then just use silicone to fix it.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Miami, FL.
    151
    It looks like its leaking from a gasket or from one of the screws om the side cover.
    Mudder Fu@#er
    85 Auto 200X
    81 185s
