Results 1 to 15 of 15
Thread: Strength Test ■ vs. ▲
    Sep 2005
    Iowa
    75
    So i broke off my shift rod on my 89 mojave. I am thinking i can repair it with some custom attention. I have about 1" still sticking out of the side of the case, my plan it to grind the remaining shaft int either a square or a triangle. I then will attach a custom made shift rod, with either a square or triangle opening and weld it to the shaft. from there i will consrtuct my custom shifter rod.
    My question is in reguard to the shape of the cut on the shaft or if anyone would advise such a process. I think a triangle would be stronger than a square and less prone to round off. although more will have to be cut for the triangle making it weaker near the end of the grind.
    suggestions?
    83 atc 110
    85 big red 250es
    95 Kawasaki Mojave
    71 SL70 - basket case - picked up 9/9/08
    as soon as you're born you start dying so you might as well have a good time - John McCrea
    springville, PA
    6,185
    the 45 degree triangle is the strongest geometric shape which is why they use alot of them for supports and such in buildings, but in your case I would say a square since there wil be more corners to grab onto and it wont be as liable to round off.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jun 2004
    Pyeongtaek, South Korea
    474
    Actually, the equiangular, equilateral triangle is the strongest (60 degree angles). If I were to do what you are, I would use the square end because of the greater surface area and greater material at the corners to resist failure. The shear moments on the corners of the triangle would be too great, so you would round it off quickly.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Duluth MN
    803
    you are welding it so it will not move and cant round off. go square and check it once and again.
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    Roanoke, VA
    4,038
    Some driveshafts are square...need I say more?
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Jul 2003
    indiana
    892
    Tell you what I would do, I would order a new shift shaft and fix it right the first time! But seriously, if you get it to work out it might work for a while but when it breaks again it will be even harder to fix most likely.
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    Not familiar with this motor, but will you be able to get the side cover off after you weld the shifter on?
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Duluth MN
    803
    just thought of something last night. Think of a rachet. its square
    '04 Honda CRF250R
    '05 DS 90
    Jan 2005
    Spruce Head Island, Maine
    893
    square has more material in it than a triangle, the square would be stronger just because it has the added material in it.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Apr 2003
    Spanaway, WA
    1,240
    I'd just buy a new part and fix it right the first time.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Jan 2005
    893
    haha damn straight
    Past Rides:
    Sep 2005
    Iowa
    75
    Quote Originally Posted by TrikeKid
    But, the part is 100 freaking dollars, then i would also need a gasket set $100, might as well bore it and put in a new piston, port and polish the head... you see the problem there
    I have to split the case to change it!! It's not a quick and easy side cover!
    Also, the 4-wheeler was given to me!
    83 atc 110
    85 big red 250es
    95 Kawasaki Mojave
    Apr 2003
    Spanaway, WA
    1,240
    Yes, but would you rather ride knowing it was fixed right or have it break when you're in the middle of nowhere?
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '87 Tecate 4
    Sep 2005
    Massachusetts
    1,272
    Well, thats when a pair of Vise Grips comes in handy
    Sep 2005
    Iowa
    75
    Quote Originally Posted by Rm250RF900R
    Thats how I'm riding it now!!!
    83 atc 110
    85 big red 250es
    95 Kawasaki Mojave
