I polished these parts over 2 months ago, so there a little hazy.
A before and after type pic, the rezzie on it looked like the whole shock.
And an after
And an after
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
Hey, I have some socks just like that.![]()
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
83 YTM 200L For sale,
82 Tri-Zinger 60 For sale,
8? YTZ 80 Conversion,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
What did you use to polish your parts?
Originally Posted by 750fl
I have the polishing wheels and bricks, I cant rember the brand of them. I used Zepher show polish for the final stage of the polsihing, it sealed up the bling pretty well. And Lonesome those socks are so comfortable.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
He's wearing them because thats not the only things he had polished....Originally Posted by LonesomeTriZ
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Man does that ever look good 1984kxt. WOW!
And I thought I had bling with my Bling Bling 200.
Sweet job!
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
Me too! Gold Toe's? Those are great socks.Originally Posted by LonesomeTriZ
Awsome looking.I have the bricks,wheels,and cones. also.You look like you are better at it than me.Explain the stages to a good polish job.PLEASE PLEASE!!!The polishing kit I bought didn't have any directions or anything on the way to properly do it.
Thanks Man,
X
Well what I did step for step is,Originally Posted by 2XTREME
I first cleaned off all te parts with soapy water. Once I finished that , I sprayed each part with acid to get some off the corrision off so I wouldnt have to spend so much time getting it started with the first polishing brick. So once I did that, I took my heavy duty angle grinder and put the polsihing wheel on it, I then put it in a fairly big vice to anchor it to somthing. Once I did that, I turned it on applied the polishing brick to it, and took my silencer and slowly started polishing it, I moved it like a type writer, Where I would start at one end and move it down in a straight line to the other end. I spent at least an hour with the the first polishing brick on it (first polishing brick is real grittie) Once I did that, I applied the second polishing brick to the polsihng wheel, I did the same thing as last time as far as moving the silencer goes, but it took me about 25 minutes to do this step. I then swapped the polishing wheels out to a softer wheel and applied the last brick to it, I moved the silencer the same way before and this time I spent about 15 minutes doing this step. Once I finished up with that, I took some Zepher polishing compound and apllied it to the silencer rubbed it on in a circluar motion, I let it sit for about 20 minutes untill it was chalky and I dusted it off.
For the carb, I took the good ole dremmel and about 5 different polishing wheels for it and I went at it. I used, Tapered bits, Reverse tapered bits, soft and hard 2" wheels and tiny tapered wheels. I spent about 3.5 hours on the carb doing this. I used the same stuff as the silencer but on a much smaller scale, once i was done I got some Q-tips to apply the Zepher compound in the hard to get places, agian I let it sit for a whiel and dusted it off.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
hell yeah,that stuff looks good.post some pics. once you get it back together.
are you polishing other stuff too?or is this it for the project?
I still need to polish the clutch and stator covers, along with the waterpump cover, everything allmnium will be polished.Originally Posted by 3leggeddog
Ill chrome the pipe, and I plan on doing a candy apple red paint scheme for it.
Oops it is for a project, I need to get done by March.
1986 310R
1975 F150 4x4
1975 F250 4x4
1968 F100 2wd
2001 Dodge 1500 4x4
Cool,Thanks for that.I couldn't get the soft wheels to do a good job.I ended up using the hard cones,wheels,etc. for all of my polishing I did.I didn't use the Zepher.I will have to get me some.
Thanks Again,
Justin
