Results 1 to 12 of 12
Thread: Anyone put a brake light on a 250es big red?
    Jan 2005
    waverly hall, ga
    52
    I have finally got my Big Red up and running again. I do a lot of riding that ends up after dark and I would like to have a brake light on my trike. Has anyone ever tried this before, I know it can be done but could someon eenlighten my on how to got about doing this? I am the only on eout riding without a brake light and I know it would be a whole lot safer with some of the folks I ride with.
    85 250es BIG RED
    01 Yamaha Raptor 660R
    N5HNY's Avatar
    N5HNY is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Arkansas
    180
    The tail lights on a Big Red are two wire. This means they are just running lights.
    You will have to get a switch that will operate via a spring off your brake levers or pedal. I suggest the pedal.
    You might try mounting a seperate light you can wire direct to the battery through the switch.
    Vance
    Nov 2004
    Fort Kent, Maine
    2,132
    Well... I didn't put it on, but there is a brake light on my Big Red. I will try and get some pics for you soon.
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Jan 2005
    waverly hall, ga
    52
    Thanks for the info. I guess I am mainly needing to know how it is wired up so it works with the brakes.
    85 250es BIG RED
    N5HNY's Avatar
    Jan 2004
    Arkansas
    180
    Here is a drawing I did in Paint.
    It's kinda crude but maybe you can figure it out.
    Vance
    N5HNY's Avatar
    Jan 2004
    Arkansas
    180
    Your third wire is a running light. If you wire it like this it will run all the time.
    Just use the ground wire and the brake wire which will be the brightest light of the two filiments in the light bulb.
    You will have a brake light and you can use the exisiting tailights as running lights.
    Vance
    Jan 2005
    RI
    2,530
    does anyone know the site where the banjo bolts for the brake lines have a switch built into them to activate a brake light?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Duluth MN
    803
    just add another light that will come on when you stop. The second light will show stopping and you dont need to monkey with your running light.
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    Here's a write up I saved, I was thinking about adding a pair on my 4x4.
    http://home.earthlink.net/~jlcurrie/
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    I can;t remeber what there called. but autozone/advanced/ pepboys carry little LED lights that are meant to be attached with double sided tap inside your head lights. it would prbable be pretty easy to stick some white ones inside the big red lenses and wire them to a switch. ill try to find a picture of what im talking about.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Jan 2005
    waverly hall, ga
    52
    Thanks for the info guys. While we are on the subject, does any one have a good set of tail lights for sale, I am thinking of going to advanced and finding some that I can make work, any suggestions?
    85 250es BIG RED
    Nov 2004
    Fort Kent, Maine
    2,132
    Well... here is the setup on mine. Sorry for the late post... been busy around here cleaning up the 3+ feet of snow for the last couple days.
    Anywho... I didn't really check on how it is wired, but I assume it would be connected to the little wires out back that are used for accessories (at least I think that's what they're for)
    There is a little "switch" that you can see in one of the pics that has a rod going to the end of the brake cables... kind of a crude setup... but seems to work fine.
    Don't know too much about it... I'm guessing the original owner put it on to help make the trike road legal.
    Sorry for the crappy pics... all the trikes and quads are packed into the sheds for the winter and are hard to get to.
    Phil
    Attached Thumbnails Attached Thumbnails brake light 001.jpg   brake light 002.jpg   brake light 003.jpg
    '85 250SX-Rider
    Various Accessories
