Thread: Engine case number means what?
    Dec 2005
    Oroville, CA
    64
    Well I am trying to finde out what the case number means on the side of the engine. I have a few engines and I know 2 are 200x with the code TB05E- and then the number but I also have one that looks the same but has the code
    MD02E- and then the number. Anyone know how to decode them if there is a way? Thanks
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by penguin
    To my knowledge there really isn't a way to decode the motors without a Honda Identification manual. But your in luck here. I have one and keep it close to the computer. I took a W.A.G. and actually came up with a model for you. The MD02E was used in the XL185s dirtbike. For the year you need the rest of the numbers:
    1980 = MD02E-5000003~
    1981 = MD02E-5200002~
    1982 = MD02E-5300003~
    1983 = MD02E-5400006~
    Howdy
    Nov 2004
    Mass.
    90
    I too a'm looking for some help to find out what a motor came out of. In your post you stated that the code TB05E- is a 200x. The motor I need help with has that same code number on the case TB05E-6305257. Do you know if all the 200x's had that same code number? That would answer part of my request. Hope it is and I'm also looking for a year. (need to buy some parts for it) Thanks Big D.
    Parts for sale
    85 KX250 Roller with engine
    KDX motor
    2004 E-Ton Viper 50 Needs work
    Honda 87 Fat Cat Roller
    Honda 200m motor
    Honda 110. 80 frame 82 motor For parts. Runs.
    Honda 84 ATC 70 Roller Cheap.
    XR75 complete bike
    XR80 parts
    Yamaha 225dx parts.
    Honda 84 200es parts Good bottom end. (quad conversion front end)
    Kawasaki 93 KX80 Motor (needs piston & bore)
    Yamaha 88 YZ125 cases
    Suzuki 85-87 LT230s 2 complete parts bikes.
    Honda 83-85 200x Parts
    Honda 86-87 200x Parts
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Big D
    http://www.3wheelerworld.com/1986HondaSpecpage.shtml
    1986 model motor.
    Howdy
    springville, PA
    6,185
    http://atcheaven.com/Model_ids.htm
    select your CC range and it will give you all the engine #s.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
