ok ive finally got me a ricky stator lighting coil for my motor and i have a few questions before i install it:
1. the green & yellow wires go where on the coil? does the yellow go to the start of the wineding of the coil or the end it....... or does the green wire?
2. im gonna use a 12/voltage regulator in series after the yellow lighting wire, after the voltage regulator out too a fusable wire then out too the lights..... is this correct to get the corrected amount of juice to the lights and no more? the fuseable wire would be so i dont blow any bulbs..........would this set-up also correct the demness.... im useing also 45 watt haligon head lights .............................................
...................(atc200s honda) motor
