dude, get mid to top end porting, its waaay more fun...plus dont listen to these guys about these pipes and stuff, you can easily rotate the cones of the pipe and you can extend the headpipe a little without hurting the pipes effect....if you physically change the angles and length of the actual expansion chamber you will affect the effect of the pipe. trust me, ive done it. and if you are going to do this swap, do it RIGHT, take your sweet time, and line up the engine sprocket with the axle sprocket PERFECTLY, no joke, and make sure that the height of the engine sprocket is correct with the swingarm, try to keep it as close to the exact location of the original motor. if you have to weld something to the frame, prep the frame and have someone that can weld really good weld it, because with this motor the vibration will be quite a bit more than the original. good luck man, if you need any guidance i am a veteran of motor swaps and chassis building....
