Results 1 to 14 of 14
Thread: 86 tecate can you bore them or do they have to be resleeved?
    May 2004
    olean n.y
    519
    ive got an 86 t3 i just started to tear down and was'nt sure if they had to be resleeved. i know my 85 did. i'll have pics of project posted as i git-r-done. thanks nate
    Attached Thumbnails Attached Thumbnails IMG_0101.jpg   IMG_0102_1.jpg   IMG_0103.jpg   IMG_0104.jpg
    old honda dealr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    texas
    215
    that doesn't look like an 86. I see the 86 tank and radiator shrouds but looks like the rear fenders are wrong. Don't know
    Bikes I currently own.
    1985 250sx with Hondaline Tank Cover
    1986 Tecate with 1998 KX250 motor Eric Gorr 285 big bore kit.
    1985 200x sold
    1986 200X in restoration
    1981 110 stock
    1987 Big Red
    1985 250r doing total frame off rebuild.
    1985 350x with 86 fenders
    1985 350x in excellent original shape.
    1987 atc125 Near perfect.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by thornton
    The 86-87 Tecate cylinders are not Bore-able. If it's wore you will have to have it replated or get it resleeved. I had this issue with a Tecate I was fixing a few years ago. I ended up finding a complete running motor and went that route.
    Howdy
    Apr 2003
    HARTFORD CT, USA
    478
    If I had a dollar for every time thats been asked.....................
    Sleeve it bra....aftermarket maybe an LA
    then you can bore away at will good luck.
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Jan 2005
    RI
    2,530
    why would they make a cylinder that wasnt borable? Isnt that kinda an incentive not to buy them? I'm sure it made more people go buy stock cylinders from kawi, but it doesnt seem too nice of them...greedy maybe?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Newfoundland
    5,280
    The Nikisel liner disapates heat better then the cast iron sleeve. If I had my time back I would have replated my cylinder instead of sleeving it.
    Quote Originally Posted by BigGreenMachine
    Whats the life span of Nikisel if you keep it running good, aircleaner cleaned?
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Aug 2004
    Phoenix
    1,229
    Keep the nikisel!! It is much better than the iron sleeve. If you keep the air filter maintanence, mix fuel/oil, and jetting is correct then it will last literally forever. The only thing you will have to replace is piston and/or rings when they wear. (No more bore jobs!) I still have the original plating in all my tecates.
    If urs had a bad seizure and the plating is damaged then you can get it replated for about the same cost as a new sleeve installed.
    Jul 2003
    indiana
    892
    Looks like a colaboration of years. 84/8 fenders and front end but the engine looks 86 or 87 to me. Oh and blazer, if you keep a good airfilter in it and pull the top end every so many hours and check it out and at the most you need to put new rings in it. I will always go nikasil over a sleeve if I can
    Jan 2005
    Great Bend
    704
    there is a company outta colorado that will nikisil any cylinder you want.
    www.kustom-kraft.com
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Feb 2005
    Oregon
    772
    Nikilsilhas my vote, it transfers heat better, has less friction and produces more horsepower. I have the original nikasil bore in my tecate, I have ran only 32:1 and service the airfilter every month of riding.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Newfoundland
    5,280
    Thorton, your wheels are on backwards. The shallow section is supposed to be inside bro.
    Upper Black Eddy , pa
    245
    so is that an 86 ?
    1973 atc90k1
    cobra exhaust,1978 thumb throttle ,& pegs
    '80 honda 110
    '84 yamaha 200 x2
    '85 yamaha 225 dx 4sale
    '85 tecate 3 basketcase
    '85 honda 200x
    '02 blaster race quad getting full rebuild
    '88 suzuki quadzilla sold miss it
    '00 honda XR650R supermoto
    Feb 2005
    Oregon
    772
    Its an 86 that looks a little goofy, Pipe exits out of the right side, frame, tank and shrouds.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
