Results 1 to 10 of 10
Thread: Holley carb identification
    Michigan
    1,220
    Anyone know how to identify what size a Holley carb is? I've got a duel quad hi rise setup I want to list but I don't know what size the carbs are.
    az
    2,007
    just google the list number and Im sure you'll get a bunch of hits on the cfm
    Aug 2004
    Ab Canada
    4,368
    Normally-if i remember correctly the holly's are cast numbers on it..or was it a sticker,,i know its on the carb somewhere...
    1985 Tri-Z-
    Dec 2005
    Oroville, CA
    64
    Post the numbers on the carb and I can tell you what it is.
    az
    2,007
    the numbers or on the choke horn. like 3310-1 I think it will say list then the number.
    Michigan
    1,220
    Looks like the choke assemblies are missing from these carbs. The only other numbers I can find are 997 on the meetering block (if thats what it is) and 6R3359 on the top of the carb under the air cleaner.
    Nov 2001
    B.C.
    933
    The numbers will be right near the front air horn, see pic. Yours look to a 600 vacuum secondary, but the numbers will tell all.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    I'd guess 600's.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
    az
    2,007
    could be 450 or 390 vacuum secondary, since its a small block set up. Jim
    az
    2,007
    by the way what do you want for it? I think a tunnel rammed small block would look kinda cool in my camaro. Jim
