Hi,
I re installed the motor in my 1984 ATC 250R today, put the swinger back on, put the chain on, hooked the clutch up, rebuilt the carb, and then when i went to kick it over, it will "jam up" then free itself, it almost feels like the piston is actually in total slop inside the cylinder and its jamming against the wall of the cylinder and causing it not to go. I dont get it, before I removed the motor, it would kick over fine. I did a compression check and I have 130 PSI which is plenty, this really has me boggled...
I thought maybe the cylinder was dry, so I sprayed some lube down in there (only a little bit, just to cover the wall) and then kicked it over by hand with the plug out, then when i put the plug in, it still did the same thing. It doesnt feel like crank, because there isnt any "crunch" to the bottom end or anything, and it only does it when the plug is in.
Could it be possible that the whole motor is shifting and not letting me get a good kick on it? I lost a nut and i didnt have any fine thread metric nuts, and the motor does seem to move a little bit when i go to kick it over, but I dont think it would cause it to jam up...
Any thoughts? I want to ride this thing tommorow!!!
Curtis
