Results 1 to 7 of 7
Thread: CB 750 Streetbike Trike Conversion Info
    Newfoundland
    5,280
    Its pretty sparse if you ask me, think we need some light to shine down on the shady subject. 4cylinders, care to explain how your conversion went? I'm real curious as most CB's I see are dual shock and not the mono setup of the X. Fill me in?
    I'm thinking of a 87 Gix 750 conversion using the same basic parts, maybe custom tripples and USD forks, fat Hoosier front tire and 22 inch Hoosiers on the back. Prollay a 7/11 motor swap and an R1 tail piece. PIMP! Now mind you it won't be for another 4 maybe 5 years but it'll be done and street legal to boot using the bike VIN.
    hey, used a 200x for the rear sub-frame, and the frontend. the upper shock mount is on the sub-frame of the x. the whole thing went together in about a month of spare time, but this was the third time. only had to alter the stem on the tripple to use the x frontend.
    one cylinder is not enough!!
    arizona
    550
    those conversions are sick. most ive seen around here were based on the 350x frame though.
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    Yeah we are in the process of doing one at our shop. But on a cb 350, all we did was move the shocks and chop the swingarm uup, and rewelded it, and used a 200s axle carrier and axle. We'll try to take some pictures. Its almost done
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    Newfoundland
    5,280
    What year CB's work? Does it use the X swinger bolt and does the X shock bolt in place? You must have made a mono shock mount on the CB chassis cause all the years I see use the dual shock setup. The 80's CB's have some nice lines to work with.
    Anyone have some pics of 750 trikes?
    Tap is offline New to the board Arm chair racerNew to the board
    Southern Illinois
    22
    anyone have pictures of these?
    hey, any bike you can come up with will do. using the bike frame will let you use the bike gas tank. a 5 gal gas tank is nice sometimes. use the bolt for the bike, space the swing arm to center it. lining up the sprockets might be kind of tricky. try looking for pictures on my old posts.
