Results 1 to 11 of 11
Thread: What all Honda swingarms should have!
    Mar 2004
    North Central Ohio!!
    2,712
    I had my factory swinger extended last week and while I was at it, I had a rear chain guide added. This one is off a banshee. Cheap insurance for case protection!
    Yamaha has been using these for years and they WORK! I've never thrown a chain on the Z, even with terrible swingarm bearings, stretched chain, etc. On the other hand, every Honda i've known has thrown the chain on occasion. I figure, before it happens to mine, i'll try to prevent it!
    Maryland
    3,077
    Ummm dude. Please tell me that is a mirror image or sooemthing because if it isn't it looks like you put that slider on the wrong side of the arm.
    EDIT: Ok I just looked at the picture again, it is a mirror. Whew. Almost scared for you there. lol. Good idea.
    Sep 2005
    Massachusetts
    1,272
    The pro-link sticker is backwards so I guess it is a mirror image.. Great idea. I know those old Suzuki lt230s quadsports could use one of those. Those are notorious for throwing there chains and wrecking the magneto cover.
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    that sure doenst look right to me, are you putting the chain on the other side? the carrrier appears to be in backwards, and the guide seems to be on the wrong side
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    i thought the answer was a yamaha attached to it.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    They call that a reverse negative.
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    Yeah, you're right Holmstrom, if you meant attached as in a tow rope!
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Mar 2004
    2,712
    Yes the image is reversed somehow. I'm not sure how that happened.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Derrick Adams
    Here Derrick, I fixed it for you.
    Howdy
    May 2002
    610
    Let us know how it holds up.
    Sam from Florida
    1985 BIGRED $ 200X
    Mar 2003
    Kansas
    1,507
    Quote Originally Posted by Louis Mielke
    If you put them on both sides.. thats extra protection.. you didnt know that? :P
