Page 12 of 18 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 166 to 180 of 266
Thread: CR250R Conversion to ATCR250R
  1. #166
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Is there a reason why you would chop up a perfectly good CR dirt bike?
    If you wanted a race trike, buy a 250R or something and mod the hell out of it.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
  2. #167
    3leggeddog's Avatar
    Nov 2004
    well the cr makes 40-45 horse stock,thats 1 good reason.another is the newer suspinsion,with more travel,and better damping.aluminum framed.
    and just flat out SIICK as hell are few other reasons!!
  3. #168
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by 3leggeddog
    Is that the 4 stroke CR motor?
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
  4. #169
    Belsano, PA
    1,387
    Dime a dozen.....
    Quote Originally Posted by crackshot
    Well, lets see if I can explain it for ya. How many CR250s are out there for sale on ANY given day? I can pull out the local Trader Paper and find about 10 within a 45min drive. I figured it is no great loss to "donate" this one or many. Now, before I actually agree that I "chopped up" a bike....Nothing except for the swingarm has actually been modified. You can pick up a used swinger on Ebay for under $100 all day long....go look. The original triples are sitting on the table...I just pressed out the stem and built new ones. The frame is NOT being modified in the least bit. The seat MAY have to be cut up, but not sure just yet. Depends on my pal Derrick's choice of procedures. The subframe is remaining intact too, as I will be building a new one from scratch at some point. Mostly everything you see that ISN'T CR250 stuff, is either custom built, or brand new OEM/Aftermarket parts. The whole rear end can be bolted onto a Banshee...it is all aftermark Banshee Parts. No CR stuff back there. The front wheel...NOS 350X from Ebay. The front disc....nearly shot anyway....CR250, but NOT modified....a custom built spacer plate to mount on the 350X hub. Front Brakes....CR original...not modded. The rear....Brand New OEM Banshee. Plastics....New Maier Front 200X, rear....Used Honda 450R for the prototype and a New Maier 450R after all custom fitment is tested on the beater. (using Maier to get a better color match)
    I could go on about EVERY little part I am using, modding, but the fact remains...this bike could be put back to its original version with about $100 investment and a days labor.
    BTW, if you are getting bent outta shape about THIS one, JUST wait till you see my CRF450 I will be building AFTER this ones SELLS!!!!! I want a Thumper! As for buying a ATC250R and modding the hell outta it....still doubt it would work as well as this...(if it turns out like I hope it does)
    Lastly, Brandon's words probably would have been enough, but I figured I would let ya in on the rest.
    Again, like B said.....
  5. #170
    crackshot's Avatar
    Idaho
    1,024
    I don't see why you don't just transplant motor in frame.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
  6. #171
    Marion, Ohio
    622
    Does an atc have inverted forks? No. Does it have as much rear suspension travel? No. Do 250r's have beefy aluminum frames? No. Its not all about performance either. He wants something rare that he can say no one or very few others have. Why do you seem so against this?
    I got nothing...
  7. #172
    Dec 2002
    749
    Hey Speedbump how much did the aluminum cost for your tripple trees. Im building a set for my 426 and Im curious what kind of aluminum and the dimensions of your tripple trees.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
  8. #173
    May 2003
    Houston, Texas
    2,409
    Maybe you just won't ever understand why most folks here think that this is the project to watch.
    To each his own.
    I think its awesome for all the reasons stated above.
    Keep going speed bump!!
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
  9. #174
    Apr 2006
    oakridge oregon
    124
    speed bump..... make sure you make your swingarm strong .I converted a 91 KTM 540 twostroke in to a tecate 3 wheeler. kept dirt bike suspension geometry and had to rebuild the swingarm once and modify it two more times be for it was right. the 3 wheeler axle and tires are way more load then the dirt bike tire. sure makes for a fun 3 wheeler when it`s right
  10. #175
    Belsano, PA
    1,387
    Quote Originally Posted by 3WheelsForever
    6061 Billet.....around $100 for the stock. The dimensions are a bit harder to give.....also, you will have a complete diff setup for your Yamaha. You should just take your stock motorcycle trips, and they will use them for the measurements.
    Quote Originally Posted by moose 53
    Thanks for the advice. It WILL be strong...I don't like things breaking....not so much because of the loss of parts, time or money, but when they break, I usually end up in the dirt....holding some part of my body!!!! LOL!!!
  11. #176
    85ytz250n is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Waynesboro, MS
    338
    Kick *Edited**Edited**Edited**Edited**Edited* project
    Just wanted to drop my .02 in on this thing. I think you are doing a damn fine job, and are going to have a very unique and sick ride. I admire all the guys on here that get a basket case and then turn it into a mint machine again, but i admire you to. I am not saying that resto isnt a kick ass thing, I am just saying that taking one bike back to stock isnt near as interesting to me as taking 4 or 5 and making the whole deal look like it was produced by a factory. I wish you luck on your endever, and hopefully it will be what you expect it to be.
    Keep the rubber side down.
    Barry
    There are no stupid questions, but there are alot of stupid people out there that ask questions.
    None of us are capable of screwing things up as bad as a group of us.
    "NON SIBI, SED OMNIBUS"
  12. #177
    May 2003
    Houston, Texas
    2,409
    Whoa man...tell me about this projecT!!!!!!!!!
    I have a '94 KTM 550!!
    I won't convert it but would love to see yours!!
    Dirtbikes:
    1988 Yamaha DT
  13. #178
    Belsano, PA
    1,387
    New Pics
    Couple pics of the swinger...got some progress. Tacked up and only need a few more cuts then off to the welder to get finished.
    BTW, I had to polish the parts of the swinger first, too hard to do it after it is all welded up.
    Attached Thumbnails Attached Thumbnails reararm 007.jpg   reararm 014.jpg   reararm 018.jpg   reararm 035.jpg   reararm 037.jpg   reararm 107.jpg
  14. #179
    Newfoundland
    5,280
    Jesum man that thing is going to be a wild one!! Staying that long on the swinger?
  15. #180
    Belsano, PA
    1,387
    Lenght,
    I think I am gonna stick with it as is. The lenght is 23" from the pivot bolt to the axle. I am afraid to go too short and have the thing too hard to keep the frontend down. It also will look dopey if I get it too short. I want to be able to get off the line real hard. After I get it all up and running, I will decide to keep it or shorten it up some. It will not be too hard to knock out an 1 or 2 if needed. Nice straight tubes to chop off.
    Couple more pics.
