Wow,
Thanks to Howdy getting me a near mint pull starter I now have a running trike!
I have no idea how long this thing sat non-running, but it sure is now.
I installed the new pull starter (electric is shot) put some fresh gas in and started pulling. It sputtered to life after about 20 pulls. I reved it up a bit and what do you know it idled perfectly. I didn't even have to clean out the carb.
After that all I did was change the oil. Now it starts on the 1st pull!
Now all thats left to do is change out the swing arm bearings and seals and it will be rideable. Does anyone have any advise on that job? From what I read on the board it can be a real pain. If anyone has experience please help me out.
Thanks,
TRI-MOTO-MAN
and a piece of round stock brass. My mistake was that I crushed the end of the axle shaft where the hole is drilled for the cotter pin to go through the castle nut that holds the hub assembly on. Once you get the axle loose it is a piece of cake. I had to saw off the end of my axle shaft where it was smashed, redrill it and put a thinner washer on before I could cotter pin the hub on mine. Perhaps ask Howdy what he has done. I need to ask Him some questions myself. You might find it in a manual, but from some of my experiences they always tell it like you can tap it with a rubber
