Results 1 to 15 of 17
Thread: crank cash slushy!! NOt good.
    leroy, new york
    1,025
    ONe of my friends sunk his 200m in my swamp and we went to put it into gear today and it noticed it would not shift out of 1st checked the oil and it was gray and frozen. the Crank case was full of water and oil, and it frozen almost solid (like a slushie). if i thaw it out and put fresh oil in it, will it goe back to normal. HOw would it get in there.
    Bartlett TN
    3,083
    You are going to have to get some lube in there asap cuz the parts are probably starting to rust and that would be bad.
    86-87 Tecate ROCK!
    Jan 2005
    Spruce Head Island, Maine
    893
    make sure you flush it with a few quarts before you refill it, maybe with some kerosene or something, but you want it well flushed before you refill
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Sep 2005
    Lipetsk, Russia
    2,824
    crankcase breather hose, that's how it got in there. You need to route them up and out (under the seat is nice).
    springville, PA
    6,185
    I hope your bearings didnt freeze up. You'll know once you start it up. Good Luck
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by trikes4life
    I think you answered your own question!
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Dec 2002
    salem, nh
    1,339
    what if it sat and the bearings froze? could you tear down to the block and soak the crank in oil to get it moving?
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by kilabeez0
    More like solvent or Marvel Mystery Oil or WD-40.
    Jun 2004
    potsdam ny
    1,227
    i would completely drain the motor of all wwater possible and fill it with oil and change it after it warms up at least 2-3 times before you beat on it.... make sure the oil isnt gray after the last oil change before you ride it...
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Use ATF to absorb the water. If the water in the motor froze, your buddy is probably SOL.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    leroy, new york
    1,025
    Whats ATF??
    Oct 2005
    North Branch, MI
    196
    uh, Automatic Transmission Fluid
    Nov 2004
    Atlanta TX 3-states area
    1,592
    It will take a while to get the water out of there, I speak first hand on filling one up with water. I am actually quite good at it, it seems. IF you use regular oil then get ready to go through about 6-8 quarts before you get all that water out.
    I finally took a suck gun and pulled all the oil/water mix out of the engine that I could, the topped it back off with Yamaha 2-stroke oil and let it run for a few minutes (5 tops). After doing that twice and leaving the drain plug out for 3 days the engine was water free and runs great.
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    Flipped my 185s in a irrigation canal once and the only thing that kept it from sinking was the tires!
    It took 3 gallons of oil to completely flush the engine.
    I filled it, ran it, put in gear and rode down street then drained until oil was clean with no water at all coming out. Repeat process.
    Use cheap wally world oil in gallon container. Use 10-30 also because it will run out faster than 40 weight.
    My 185 is still running to this day and that was 4 years ago.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Anaheim
    1,270
    this is dangerous but i dont it once with a sunk k5 blazer... burried it ahd the motor suck in water and hydro locked it.... there was no mud... just water but crappy brown dirty water... drained it and flushed it with 5 gallons of fuel (poored straight into the intake manifold and cranked it with spark plugs out... then put it back together with tranny fluid as oil and poored 110vp down into the cylinders again... put the spark plugs in cranked it over shot 5 foot flame out the tail pipes (sounded like a RPG hit the barn) i let her idle for about 2 minutes then drained it again filled her back with tranny oil ran her down the raod and back accouple times for mayb 15 minutes drained the tranny flued then put 30w in it with marvel mystery oil... ran her for 2 days like that and never looked back.. the water sat in the motor for 1 day (really over night) becuase she was stuck and had to go get the back hoe.... but she ran good and still is runnin on that motor
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
