Results 1 to 15 of 16
Thread: Shaft drive, Chain drive question
    Ashland City, TN
    2,576
    Ok, it seems to me shaft drive is much much better system than chain drive, more reliable, etc. So my question is, why doesn't every atv use it? No cracked cases to worry about, cracked plastics from chains taking flying lessons, and anything else that may happen from a chain coming apart. Why is chain drive continuing to be used when in my eyes shaft drive is much better? There must be something I don't know about all this.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Feb 2003
    California
    623
    chain,shaft
    Maybe its because a chain is lighter. Easier to take care of ?
    Dec 2002
    Kansas
    2,387
    The shaft drive is basically maintanence free. Shaft drive looses alot of horsepower through the gears. Shaft drive cannot have asmuch suspension travel.
    Josh
    I had the RIGHT to remain silent, I didn't have the ability!
    Ashland City, TN
    2,576
    Oh, I see. So basically if you want more direct power go for a chain huh?
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I think another point is that chain drive is cheaper to manufacture. Another thing it is lighter too
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Minnesota
    790
    I love shaft drive. Yeah, Its hard to have very much travel, and chain drive is more simple and lighter.
    More Peak horsepower is acheivable with a chain, but Shafts are 99% maintenance fee.
    Nov 2001
    B.C.
    933
    Ever tried to change the final drive ratio on a shaft machine?? Good Luck!
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Ashland City, TN
    2,576
    I think it could be possible, just not easy...
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    I forget who but someone who posts here lost his case when his drive shaft died. I hope mine decides to go away more quietly than that.
    Nov 2001
    B.C.
    933
    If there are optional gearsets available for a shaft system, I'd like to find out where they are available from. Up to this point, I have not found any, so one would be stuck with the factory ratio.
    Apr 2002
    s.w. michigan
    6,498
    shaft
    i would also like to have sx gearing in my es
    i hope to god i never haft to take my engine out of my big red again !
    that drive shaft bout drove me to tears getting it in + out.
    john
    Ashland City, TN
    2,576
    Really? Did it stick in out or something? Maybe Yamaha did do something good, I was able to take mine off right where it bolts up to the engine so i was able to slide my motor right in and out.
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Apr 2002
    s.w. michigan
    6,498
    a bear of a time
    oh ya gotta slide back the spring loaded spline that go over the output shaft, plus you got the rubber boot in your way, limited room. it's one of those things you either get right away (never ) or you spend a hour dinking around. the book makes it sound soooo simple. it ain't !
    Ashland City, TN
    2,576
    That sounds pretty hard. The hardest part to mine is matching up the hub part the the part that sticks out of the engine. Not too bad at all.
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
