Another Point on Chain Drives is that they are more forgiving say when you miss a gear or are a bit rough with the clutch, they have a bit of built in shock absorbing that a shaft setup doesn't have, and there is usually a cush shock absorber attached to the rear sprocket, also its a lot easier to mess about with your gearing, with different sprockets if you're racing or tuning.
Nat
