Results 1 to 8 of 8
Thread: one more time...
    Ithaca, NY
    2,596
    one more time...
    I still cant figure out my golf cart. (LT 230 S) only starts when pulled down the road, then runs great. New top end, plug and carb rebuild, just cant kick start it. any intelligent replies wanted!
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Dec 2002
    Missouri
    946
    Sounds like low compression :?: That blaster motor i am getting needs a top end but it will run if pulled behind a truck or something
    06 TRX450r , 85 ATC250r, 01 TRX300ex, 84 ATC110
    88 Mustang GT
    dogger is offline At The Back Of The Pack Arm chair racerFirst time rider
    I dout it's low compression cause he just rebuilt it. sounds like your timing's off a little bite. you probly got it jup's like one tooth on the sprocket or something. I had teh same thing happen on a 200x. check all your timing mark's agian and check the timing chain tension.
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    I agree 1010% with dogger on this one. I would almost bet my life that that is what is wrong with it from everything you have said in the past.Check the timing, I betr you'd be suprised.
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    Ithaca, NY
    2,596
    ok guys, it looked DEAD NUTS correct when I assembled it. Im willing to tear it back apart and try again, But Im not 100% sure on what to do, after the cam sprocket is APPARENTLY at its correct position. I have moved the location before, no results. Im stumped. How can you "check" the timing on this thing? there is no sight window in the side case., you gotta drain the oil and take the side cover off............... major PITA
    Detroit, MI
    837
    Take the plug out and heat it with a candle or lighter fora few minutes. If it starts right up after that you know it's a coil.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    lt 230
    I hate to be a pain, but I've had 2 lt 230's qne was really hard to start. I reset the valve lash, and it would start on 2 kicks. Try it you'll like it!
    Minnesota
    784
    I've seen a rebuilt 200x with 10.25-1 not have compression after a fresh rebuild. Well, not as much compression as it should. I took out the spark plug, slowly kicked it a few times put the plug back in and it had compression (yes the plug was tight to begin with). Maybe the rings were stuck for a bit, not sure, but it runs fine now.
