Originally Posted by
patblkwell
Ok, I am now in the process of restoring the 350X I got a few weeks ago and the front brakes were all messed up-both the caliper and the reservoir. I got another reservoir from a friend of mine and took it completely apart, cleaned it out, and installed a new spring/piston assembly to deliver brake fluid to the caliper. This is the first bike I've owned with the disc brakes....
HERE'S THE QUESTION, when you squeeze the brake handle, should brake fluid always come out of the brake line or just air sometimes? I filled up the reservoir with brake fluid and there are no leaks and what not, I squeezed in the brake lever several times and no fluid was dispensed from the reservoir?? This can't be right?? Also, I still haven't been able to get the pistons out of the caliper, I may have to find a higher source of air pressure to blow them out with than what I am using now..
So your saying when you squeeze the handle no fluid comes out?
If so it's real simple, you just need to bleed them. if so heres what you do. ( it may require 2 people) fill the reservoir with fluid, then you squeeze and let go of the lever a few times until it feels like it has built up a little pressure. Once it builds up pressure squeeze the lever and hold it. while your holding the lever, losen the screw on the caliper (looks kinda like a grease zirk) until the brake lever squeezes all the way to the handle bars (or as far as it goes). Fluid might come out and it might not. either way, tighten the screw back up (snug) and then let go of the brake lever. pump the brake lever again until it builds up a little pressure and do it all over again.
You will want to keep doing this until you have nothing but a steady stream of fluid coming out of the caliper for a good 4 or 5 times of doing that "cycle".
Well i hope this helps and it's what you needed, if not then hopefully someone will see it and now know how to bleed brakes.
Kevin
- Chick McGee
-1985 250sx
- 1986 atc310R drag bike
- 1981 110 chopper.
- 1985/6 350x
- 2-84 atc250r's and 1 83
- 2002 trx400ex
- 1985 atc 250r
-1985 atc70 WTB PARTS
- 1985 tecate
