Results 1 to 10 of 10
Thread: 86 250r atc exhaust whatcha runnin?
    Aug 2002
    NY
    2,652
    what do you guys with the 250rs run for exhaust. i have an FMF set up on mine but thats how i bought it. i am not familar with the FMF but like it so far. when i restore the r i want to put a low to mid range pipe and silencer on so again what do you all run thanks mike
    PLJ. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    253
    Pipes
    I also had an FMF on an 85 a few years ago. The bike was stock except for the pipe and silencer. The pipe gave the bike a nice top end, but it realy cut down on the low end. It needed alot of clutch work in the woods. I did not like it that well. I bought a huge Trinity pipe this summer for the ATC but I have not had a chance to run it yet. I have heard that the Paul Turner "high rev" is the best all around pipe for the ATC, but I have also heard that the Bills pipe gives a great bottom and midrange boost. Choices!!!!!!!!!!!!!
    Roanoke, VA
    4,038
    My brother had a FMF fatty on his '86. It really brought out the low end.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    CartmanKXT250 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Traverse City, Michigan
    198
    my choice was an ftz out of frame drag pipe........I hear ESR also makes a good pipe.
    03' Silverado SS | 04' YFZ450 | 87' TRX250R
    www.silverlakesandduners.com
    ELake on the forums.
    theeechozen1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    368
    Ive got the FMF fatty, I LOVE IT! tons of bottom end power
    1985 YAMI TRI-Z RZ350 POWERED
    1986 250R STOCK WITH FMF & K&N
    1986 TRX70 mini golf cart
    TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
    Dec 2002
    Spruce Pine, Alabama
    1,263
    I've asked for opinions on other boards about pipe performance, and I've gotten varying, often contradicting opinions. I've heard that the Paul Turner Hi Rev was the pipe to have for mid range to top end, then I've heard from someone that used a PT that the ESR ATC5 was a better pipe for upper range power. I've heard that the FMF was good for low end, and bad for low end.
    I'm wanting a mid-top end pipe, personally, and I'm kinda stuck trying to decide which way to go. The most solid testimony yet is the one mentioned above from the guy that owned both the PT and the ESR ATC5. I definitely like the price of the ESR better, but performance concerns me most. I sold a perfect DG for $50 and could buy it back for the same money, but according to what I've read here, it's not as good as the others mentioned.
    '84 ATC70.....my 8-y.o. son's ride
    Mar 2003
    West Monroe, LA
    847
    FMF Pipe
    I Run FMF fatty and I love it. It made a noticable diff. thru out the entire RPM range.
    San Diego, Ca
    66
    Well I run the Paul Turner Hi-Rev with an FMF Power core II silencer. I love this set-up. I ride only dunes with this bike, and it has so much top-end it's crazy. The low end is still there, about the same as stock, but it will rev to the moon. I love this Pipe. I have never heard anything bad about it. Paul turner also makes a low-mid pipe. check out www.duncanracing.com for more information.
    1975 ATC90 for sale
    1985 ATC250R
    2 X 2004 YFZ 450's
    2006 Yamaha Rhino
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    fatty pipe, power core silencer.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    dogger is offline At The Back Of The Pack Arm chair racerFirst time rider
    fmf fattyy's are a good bottom end pipe. I'mgoing to put on a atc 5 on my r they are supposed to be a littler better for all around use. paul high rev's aren't that great off a pipe unless your in the dune's though.
