Thread: Another ALT 125 Question
    Missouri
    3
    Exclamation Another ALT 125 Question
    Got my trike running again, however, noticed backfire through the suction?? line running from the intake manifold-between the carb and cylinder housing-to the fuel pump/filter down by the gas tank.
    Anyone out there have a clue what this might mean????
    Also as a new member to this board, I want to tell you all that this is a great way to find out info from the pros!!!!!!
    Feb 2005
    Canada
    663
    Maby its an incorrect Fuel/air mix. Try adjusting the idle screws or somthing.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Missouri
    3
    Thanks for the reply- As a first time owner, I am just trying to fumble my way through this thing and since it was free I figured what the H***!
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    backfire mean timing, you timing MIGHT be off just a tad. look into that.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    springville, PA
    6,185
    Ok a couple of questions for ya.
    Q1. Is it doing this during the cold months or just all the time?
    Q2. Do you hear a ticking like 2 spoons hitting together when your engine is running?
    Q3. When you say running again, what do you mean? Didi it have to be taken apart?
    Hopefully when you answer these questions we can better help you.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by walleye
    Welcome to the site. We hope you enjoy it.
    Can you give us a little more info here:
    Has the machine sat for any length of time?
    Has any top end work been done?
    Does the motor Run good?
    Does it seem to have much compression?
    Does it backfire throught the carb as well?
    The more info you give the better we will be able to help diagnos your problem and then give reccomendations to fix / correct it ( if needed ).
    Thanks
    Howdy
