Results 1 to 11 of 11
Thread: 84 200es no gas to plug
    Aug 2004
    Dauphin, PA
    100
    When I pull the spark plug - it is dry. I am getting gas out of the petcock - its real tight into the carb so didn't have time to play with that. Any suggestions?
    springville, PA
    6,185
    any gas leaking out of the carb? Might be some rust from the tank got in the carb and plugged it up.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2004
    Dauphin, PA
    100
    Nope - carb is not leaking. It wasn't starting so I pulled the plug and it is dry - no gas at all.
    Do I have to take the carb off and apart?
    Aug 2004
    Ab Canada
    4,368
    Clean the carb...prolly full o crap
    1985 Tri-Z-
    Aug 2004
    Dauphin, PA
    100
    BTW its a brand new carb
    springville, PA
    6,185
    well if you have gas to the carb but no gas to the plug, yes its the carb. If your still hesitant about taking the carb apart I can send you the link to a thread I made about how to take apart and clean the 200es carb
    Nate
    R.I.P HRR
    Aug 2004
    Dauphin, PA
    100
    Please send the link - thanks nate!!
    springville, PA
    6,185
    Nate
    R.I.P HRR
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    wait, try this first, i had the exact same problem. do these trikes had air-fuel mixture screw? if so adjust and play with it.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    hey, those engines are known for losing valve lash. check the valve lash before you take the carb off, should be .002 both valves.
    one cylinder is not enough!!
    Aug 2004
    Dauphin, PA
    100
    Well took the carb apart along with the small jet - blasted air and carb cleaner in both main and small jet. Reinstalled and still no gas to plub - Am I missing something and doing something wrong?
    Again carb is new - looks great - and all passages that I know of are what appears to be open.
