Thread: how to fix a cases?
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    how to fix a cases?
    well on my 110 the cahins came off and broke the chain case. i tired jb welding it but i find it doesn't hold for too long is there something i'm doing wrong or another way to fix it ?
    Thanks.
    Evam
    1985 suzuki alt 185
    1985 honda atc 250sx
    1985 honda atc 200m (all apart)
    1984 honda atc 200es
    1984 honda atc 200x- need motor, plastics, axle, exhaust.
    1984 honda atc 125m- times 2
    1985 honda atc 200m all apart
    1983 honda atc 200e times 2
    1983 honda atc 250r-times 2
    1983 honda atc 200 4 parts
    1983 honda atc 110 times 3
    1979 honda atc 110 smokey
    1978 honda atc 90- restored
    Have lots of extra parts, if interested email at e_mcy@hotmail.com
    take it off and take to someone that can weld alum. or just find a new case jb weld only lasts so long nice if your stuck in the woods but not a good fix!!!if it a crack they can weld it right up even small hole , big hole scrap it the price of alum. isnt bad right now!lol sorry about your luck that allways sucks!
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    cases are plentiful if you can't find a differant case i will send you one for shipping cost
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Mar 2005
    ma
    988
    Quote Originally Posted by bryan raffa
    you can weld from a small hole or crack to a big hole. you just cut out a scrap piece of aluminum and weld it to the case, very easy. i've done it enough times.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    zoomerman's Avatar
    Ontario, Canada
    351
    ok thanks for the replies i didn't really want to replace the case because i would need a new shifting rod and shifter they are wleded on
    1985 suzuki alt 185
    Mar 2005
    ma
    988
    well just grind them off and reweld them on!
    if you want to use jb weld, make sure you clean it good, and remove all the oil, and dirt. let it dry and then put it on. it should hold up for awhile if done right. but it shouldn't be a permanat fix.
    My Feedback
