Results 1 to 7 of 7
Thread: Need Help
    sacramento ca
    3
    Need Help
    Hi, all I bought a 200s about a month ago. And its pretty clean. well long story short I dropped a piece of metal in the spark plug hole. So I took it all apart got it out, put it all back togather. And now it wont start. I have spark and fuel. So any help would be great It's driving me crazy. Thanks JOhn
    Dec 2005
    Tulare California
    Was the bike running properly before the breakedown? I would test your spark and compression. If you washed out your rings from trying to start it then you will need to put about 2 table spoons of oil in the spark plug hole. Put your plug in and try it. It will smoke for a few mins if it does start but that will go away. Anyone els agree? Also check gaps and cdi.
    Jan 2005
    RI
    2,530
    did you use a manual? Do you know how to time it?
    http:\\deepa.recongamer.com has the manual for the 200s free to download...look through it and see where you went wrong...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Oct 2005
    Pennsylvania
    863
    your pulse rotor is probably upside down, ---Common mistake----D/L s manual and time it properly, There are two ways the rotor assembly can go on---
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    sacramento ca
    3
    Thanks, I cant download it for some reason. If I could go buy one I would( If I had a place to get one). Maybe somebody can send me the page. This is driving me crazy e-mail is thecanevaris@yahoo.com thanks
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    Quote Originally Posted by Unclediezel
    Completely agree here!! Very common mistake, rotate the rotor 180 put it back together and give it a go, alot easy that pulling back apart. Are you certain some of that metal did not get stuck under one of your valves? It doesn't take much to cause it not to start.
    sacramento ca
    3
    I rotated it last night and again two times today with no help. No there was nothing else in there. Well we have two 200s and we took the cdi apart to look at it. And now both of them wont start.
