Results 1 to 8 of 8
Thread: She lives again!
    Ontario, CANADA
    4,538
    She lives again!
    Well after 36 days of rest, the Tri-Z went for a rip today. After I fixed the cracked case, POS chain OEM chain, painted pipe and did some other stuff she was all ready to go. I was testing all the kicker gears and all that was in right, I was ready to kick her over. Must have left the kill switch on, one smooth swift stroke and no choke and she fired and purred like a kitten. I couldnt beleive it!
    Ok, water pump seal. All Z owners beware of this. It is SO brutal to get this in. I had to use a socket on each side, one on the seal other on metal other side, stick it in a vise and slowly apply pressure making sure the socket doesnt hit the seal and damage it. Got it in after I had already damaged one and had to wait another 4 days to get another in.
    I got the following new,
    OEM bolts,
    OEM side case
    OEM gaskets
    X ring gold plated chain(sprockets too)
    Water pump seal
    And a "new" used clutch assembly.
    Painted-
    Water pump cover
    Pipe
    Here are some pics, Im just SO SO happy shes all together and ready to go.
    She runs like a raped ape on fire running through a retirement home while smoking crack while being chased by rabid Walrus's.
    Just wanted to say thanks to everyone that helped me out on this one.
    New chain-
    New pipe painted-
    New case installed-
    In the process-
    And the old, POS case I had a brutally cracked!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Brandon, Manitoba
    2,209
    Those clutch covers ALWAYS crack there....POS as far as I'm concerned.
    That looks pretty good though.
    May 2005
    Dorset United Kingdom
    1,408
    MAN, that clutch cover is buggered!!!!
    Nice to know that the Z is running how she should !
    Great to know that you got her going
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    CorbinKale's Avatar
    CorbinKale is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    NE Texas
    179
    It might be the lighting in the picture, but the pic of your new chain looks like the clip on the master link is on backwards. Hate for you to crack your new case!
    Nov 2005
    turnersville NJ
    50
    I was going to say the same thing. You need to turn that clip around before you get stranded!
    Ontario, CANADA
    4,538
    Wait a tic, theres a front and backwards to it? what way should go forward? the end that doesnt open up?
    Good thing you guys are here!
    This right?- EDIT, just got chat confirmation that im a idiot and its wrong.
    #NOLINK
    #SUSPENDTHIS
    na
    5,702
    glad you got her goin again.but why was the pump seal so hard? i used a banshee seal on mine and it slid right in there. and how did the sidecover crack like that? where did you get the new sidecover from?how much was it?
    Proudly NOT a member of
    "Team on the Teat"
    Ontario, CANADA
    4,538
    The seal moshman just didnt want to fit in. She was REAL tight. I was kicking her over and wham! she cracked. I got the new cover from Yamaha out of my dealer. It was like 150 for all new bolts, case, and gaskets.
    #NOLINK
    #SUSPENDTHIS
