Results 1 to 9 of 9
Thread: i need some opinions on a 86 triz 250!!!
    Millersburg, Ohio
    25
    I have been wanting to get a honda atc 250r, but i came across a 1986 yamaha tri-z 250. Topend was rebuit in may and it is ported&polished and bored over...the guy wants $1000.. i was just wondering if that would be a good deal? thanks
    cehmke is offline The Administrators know my Other Username is kloby. New to the board
    Oklahoma
    26
    sounds like a good deal to me if plastics and such are in decent shape ....
    Millersburg, Ohio
    25
    rear plastic fenders were cut off, but other than that its in mint condition..thanks
    Nov 2002
    Kirkville, NY
    3,831
    If it's in nice shape and runs then yes sounds great.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Tap is offline New to the board Arm chair racerNew to the board
    Southern Illinois
    22
    when in doubt.....go with the yamaha lol
    May 2003
    Houston, Texas
    2,409
    If the Tri Z is running right...you will love it over the R. The R has little bottom end but a good mid range. Z's (esp the 86 have phenominal low and a strong mid).
    Stock for stock they are close but the R has a bigger hit in the middle BUT at the expense of low end. The Z is better all around motor in terms of power.
    Add a bigger carb and some porting and its up to any task. The R will allow you better part availability and engine mods however.
    Its just up to you.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    I have both bikes and I can tell you that its alot close than Dirt Wheels made it out to be. I think the '86 Z is superior....(not taking into account part availability).
    Attached Thumbnails Attached Thumbnails DSC02630.JPG   DSC02656.JPG   DSC02658.JPG
    Dirtbikes:
    1988 Yamaha DT
    Brandon, Manitoba
    2,209
    The tri-z is a lot sexier too
    There are a fair amount of parts available for the Z...Oldschoolin86 can build you a swing arm that uses a 400ex rear end so you have more axle, hub, tire choices. I'm having one made
    If someone would tell me what front axle/hub fits on the Z, I would buy one, because I want more rim and tire choices.
    A Yamaha warrior shock will bolt right on...
    A YZ 250 top end fits on the bottom end, you get a powervalve that way and you can have a better selection of reeds and cages, pistons, etc
    Actually, I think the whole YZ motor will bolt right in...So yea...There's not a lack in aftermarket parts by any means.
    May 2002
    Texas
    2,670
    Quote Originally Posted by Yamahauler
    85/86 ATC250R. Use the Z axle and spacers with the 250R hub, disc, & rim. I had to space the z caliper over to center it on the R disc. I think it was about 3/16" or 1/4" I had to space it.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
