Im rebuilindg my trike, and upon taking the rear axle assembly apart, I had no problems except getting the rear bearings out. They have been pressed in and will not come out. Any ideas?? Thanks!
Use chisel from the inside and hit it hard with a bigwhile the carrier is in a vice. That should do it.
85 ATC350X- weisco 10.25:1, uni, +3 swingarm, 3in. wheelspacers, RAD carrier, 450r muffler
85 Big Red
83 KLT200
82 ATC200
If it aint broke fix it anyway because it soon will be
I tried that, but heres the thing...One the atc200, there is an inner shaft between the two bearings that really wont allow me to get a chisel in there. I can put a screwdriver in there to beat them out, but all the screwdriver does is tear up the bearing, not knock it out. But I will try to somehow get the chisel back in there. Im sure all this rust inside wont help me though.Thanks.
put the carrier on a hot plate and let the carrier heat up. the bearings will almost fall out after the carrier is heated enough.
Your going to replace the bearings right......
Get out the BFH and beat away!![]()
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
I have a end of a crow bar that I use. With the angled end I can get pretty close to the outer part of the bearing. Normally a few taps of theand the bearing is out.
Howdy
HAve another person with you, take out the wire that holds the bearings in place, it will take a while but you can do it. And it will litterly fall out. Thats what keeps the pressure so they stay in.
put the carrier in the oven for a little while around 300 degrees. while thats heating up, put your new bearings in the freezer. ive used this technique and it works awesome. good luck!
I have found this to be a great way to get old bearings out. Get a die grinder (attachment) for an electric drill. Grind it down until it is paper thin (doesn't take very long). Use a large screwdriver and a, and just work it out with it. Once it's ground down, it will cave into itself, and fall out. I just did two bearing replacements this month this way, and it's the best way to go.
Bit looks like this:
