Page 5 of 5 FirstFirst ... 3 4 5
Results 61 to 73 of 73
Thread: Tri Z top mount fuel tank *PICS* UPDATE: Final pics on page 4.
  1. #61
    May 2002
    Texas
    2,670
    Great job on the finished product!
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
  2. #62
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    I actually like the stickers now that it is on the bike. Looks very bansheeish.
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
  3. #63
    Jun 2003
    MI
    47
    Looks great and all. {I'm not trying to be a dick} But why are the edges always squared - off - on all of these Tri Z Top Mount Fuel Tanks?
  4. #64
    Las Vegas, NV.
    2,538
    I'm no expert at fuel tank fabrication, but I would guess there are at least 3 reasons:
    1. It's easier to make a sharp-edged bend, rather than a gradual, rounded one.
    2. These tanks already hold too little fuel, and rounded edges & corners will only eat up valuable space inside.
    3. It's easier to cut out flat, geometric shapes & weld them together.
  5. #65
    May 2005
    Hobart, Oklahoma
    570
    Quote Originally Posted by Red Rider
    For me (the average do-it-yourself guy) the only way was to make it flat as possible to make it easier to weld. We did try and rouund the sides a little and the front end is rounded some. If you look at the pictures from the back, the bottom is alot wider than the top.
    All in all Red Rider hit the nail on the head with the above post.
  6. #66
    Oct 2005
    North Branch, MI
    196
    man, i think that looks great!
  7. #67
    Jan 2005
    I did not like it till you had it on the bike and it looks damn good!!!!!
  8. #68
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    I looks great. Now about that gas cap. I think the hose clamp and the way the gas cap is attached it taking away from the full beauty of the tank.
    Not knocking your work, the tank looks fantastic. I almost thought it was factory! Just giving some input.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
  9. #69
    May 2005
    Hobart, Oklahoma
    570
    Quote Originally Posted by crackshot
    I agree, but when you use 2 inch pipe there isn't a whole lot of options. My choices was what I used, a 2 inch plug(that wouldv'e looked okay but had no way to put a breather in), or a cast iron pipe cap. The cast iron pipe cap just didn't look right to me so that rubber one was my only option. I'm gonna keep looking, and maybe I can find something down the road. My advice to anyone that may try this GET YOUR GAS CAP AND NECK FIRST! When we built it we didn't think we would get as far as we did and was not prepared to put the neck on. We were making such progress though so we didn't want to stop. We had an old diesel tank and used the neck and cap off it, not knowing that the caps would be limited.
    If anyone has any ideas on what to use I'm all ears.
  10. #70
    crackshot's Avatar
    Idaho
    1,024
    Maybe lathe a chunk of billet, tap it and make it look dandy!
    Lathe down a nipple on top for splash tube.
    If you have access to a lathe or know a someone in a machine shop, It is possible. Still a great looking tank.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
  11. #71
    Sep 2003
    Elizabethtown PA
    1,581
    this will be a lttle spendy but get a quick fill gas tank piece (mite be called a dry break also) like the pro GNCC guys used on the honda trx250r's. it's on the big 4.0 gallon trx tanks. you just drop your gas can with a special end onto the tank. the flap opens and the weight of the gas can opens the valve on the gas can. lift it strait up and both things shut and you dont spill a drop.
    it fills the tank real fast i think it took under 20 seconds for the Gncc guys.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  12. #72
    Washingtons Crossing, Pa.
    2,977
    Very trick indeed. I was thinking the same thing as jason85atc250r - try and mount a dry-break system for the tank. If you perfect that cap issue - you should really consider selling them on a custom basis. I think it looks that good.
  13. #73
    Aug 2006
    Arlington, Wa
    1,027
    the tank looks great! I need one now, my wife says thanks
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
