Results 1 to 7 of 7
Thread: Plug Question
    Bender is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Chippewa Falls WI.
    234
    Plug Question
    At the tip of my plug there was a hard white piece of somethin stuck to it. What is it and what causes it?
    86 ATC 350X
    86 ATC 200x (my P.O.S.)
    ATC 70 (first trike,7 years old)
    Email: Bender@bodybuilders.com
    springville, PA
    6,185
    spark plug? If it is your spark plug than you may be running REALLY lean. Got a pic?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jun 2004
    Chippewa Falls WI.
    234
    No i dont have a pic but i know it was running lean cause i ran straight pipe all the way back and had the air box lid off and never rejeted. I noticed it when i pulled it out to rebuild the top end but after the rebuild i only whent to a 118 main jet. Is that big enough? What about the slow jet and needle clip position?
    86 ATC 350X
    springville, PA
    6,185
    what is the stock main jet?
    Nate
    R.I.P HRR
    Jun 2004
    Chippewa Falls WI.
    234
    I think it is a 108 but im not sure.
    86 ATC 350X
    springville, PA
    6,185
    if its a 108 stock you should be good if your running a straight pipe and lid off. But do a plug chop with a new plug to make sure.
    Nate
    R.I.P HRR
    springville, PA
    6,185
    for your needle positioning take a look at this thread. http://3wheelerworldforums.com/showthread.php?t=47068
    Nate
    R.I.P HRR
