I was just curious as to the opinions of you guys the best/worse gaskets. I'm gonna have to buy a top end set so any particular brand you like or dislike ect. I would sure like to know who and why.![]()
Thanks, Devin
Thanks, Devin
"I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
stick with oem gaskets. what gaskets do you need? i know i have a base, head, and exhaust flange gaskets i could hook you up with. they are still in honda packaging too. pm me if your interseted
OEM are best, the only Aftermarkt brand i have found to come close to OEM standards was Cometic, and i havent had any problems with them.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
if your getting factory honda gaskets make sure you get a ATC head gasket the TRX ones were thicker.
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
use a OEM CR head gasket I think the ATC gaskets are discontinued and they will give you a thick TRX head gasket.
i found vesrah gasket kits pretty durable
oem, vesrah, cometic are good.
I stay away from K&S.
i always stay away from vesrah Junk IMO from what i have used they are thin under-oem spec crappy sealing gaskets....Just my experiance.
1985 Tri-Z-
