Just getting ready to change the front tire on my 81 185s and I was wondering if anyone has any tips that would ease the process. It has a tube in it and the rim is rusted up pretty bad so I am going to have to use the tube again. Thanks
Good luck..if it has a tube thats even worse, you may have to take it to a tire shop to break the bead's so you can undo the split rim and take it apart...your probably gona need a new tube if its rusted in ther....they tear and get jabed with rust when you pull them out, make sure you clean all the rust off the rims and re-paint the inside before you put it backtogther.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
I already have the tire off the rim and am wondering what the best way is to put it back together? I cleaned the rim up good, do you think the tire would seal if the rim is pitted? Is there a way to smear silicone or something on the rim so that it will seal or should I just put the tube back in. If I use the tube how do I line up the split rim when I put it back together or do I bolt the rim together and try and get the tire and or tube on that way? Thanks
Spray the inside of the rim with a can of $7 do it urself bedliner it will get rid of the pits, been there done it works great.
I use dishsoap on all my tires to get the bead sealed.
Put one half of the tire on the half of the split rim, then put the tube one then the half of rim, and bolt the other half of rim on.
