Thread: 86 Tri-Z help
    Mar 2004
    32
    86 Tri-Z help
    Ok I am needing to replace a few parts and need to know what interchanges and where I should go if anyone has that advice.
    1. Clutch(mine is slipping)
    2. 86 Tri-Z front tire
    3. Front wheel bearings
    4. water pump seal(oil in coolant)
    5. swingarm bearings
    6. DG silencer
    7. OEM air box elbow off of an 86 only.
    86 Yamaha Tri-Z
    Enough mods but need more
    Ontario, CANADA
    4,538
    Ok I have a few answers for ya-
    Clutch, I think OEM is still there, if not used.
    86 front tire is discontinued, good luck!
    Water pump seal is same as banshees.
    DG silcer, Denniskirk.com
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    the only tire i could find was a maxxis front pro through parts unlimited witch I ordered the first week in nov. been on back order I think they had to make it because its not a popular tire size! keep looking on ebay !
    Watertown, New York 13601
    3,382
    Quote Originally Posted by bryan raffa
    Wish i knew you needed one. I have a like new maxxis pro front tire forsale.
    1. Clutch(mine is slipping) -Bikebandit
    2. 86 Tri-Z front tire -goodluck on that size
    3. Front wheel bearings-Bikebandit
    4. water pump seal(oil in coolant)Bikebandit
    5. swingarm bearings-Bikebandit
    6. DG silencer-Denniskirk
    7. OEM air box elbow off of an 86 only.-Maybe bikebandit
    www.bikebandit.com
    __________________
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Mar 2004
    32
    Are the Vesrah clutch springs and clutch plates any good? Will they fit my 86 Z with no problem?
    86 Yamaha Tri-Z
    na
    5,702
    you can run 85-87 yz 250 dirt bike clutch kits in the tri-z.there are many more brands to choose from.i dont have any experience with vesrah other than brake pads,and i dont personally like their brakes.i have a ebc racer clucth in my z from a yz 250 and it works really nice.
    Proudly NOT a member of
    "Team on the Teat"
