Anyone know the parts to make one of these? or which one to get?
I have seen people talk about using one but never seen or heard how to make it.
Thanks!
Thanks!
1986 ATC 350X
1986 ATC Big Red 250ES
What is a leak down tester?
vacuum/pressure gauge,threaded fitting for sparkplug hole,pressure pump,t-fitting,shut-off valve, expandable automotive freeze plugs,rubber hose. i think thats it.
2 125 yamaha tri motos
1 yt175
1991 blaster
smash the ceramic off a spark plug, cut off the matal and drill it out, thats the thread sorted. Tap the hole and screw in your fitting. Attatch a tee with a pressure gauge and a tyre valve (non return). Pump it up with your footpump or compressor - job sorted
I would just go buy one. You can find them at auto stores or order one they can come in handy I have one. You can also use fitting from compression tester to make one if you wanted.
Thanks for all the help!
1986 ATC 350X
A compresson leak down tester is different from a 2-stroke crankcase leak down tester. If you pressurize your crankcase with 100 psi you will likely create more problems than you sought to find. LOL LOL Crankcase leak down tests usually run 5 psi or so, and you pump it up with a squeese bulb. Check out macdizzy's site for leak down info. I'm guessing that is the type of leak down test you want to do........ I looked at your sig.......
86 250R
86 250R
86 250R
85 250R
82 250R
86 350X
81 185X
85 250SX
87 200X
Sitting on my can can, doing the pan-o-ram..
an aspirator bulb for pneumatic controls works, all that is a pump similar to the hand pump on what the nurse checks your blood pressure with. some dive shops carry a similar pump also.
check the duncan racing website for a tech article on this procedure.
