Results 1 to 11 of 11
Thread: Just got a trike for free
    GreyhoundRugby is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Indiana
    196
    Well I finally got a replacement for my 200x that I did some work to and sold (bought for 200 sold for 600 and finally the trike Ive ridden literaly all my life has been handed down to me from my grandpa. I always ride the little beast hard so Its not going to be a full resto but I will do some things just to clean it up at least. Now Im not sure whether its a 185 or 200 it has the Hi-Lo-Rev on the side with the selector so I think its the 200 but Im not sure. So after I have an egine rebuild or tune up at the local honda shop I want to do a couple small things to just up it. New wheels and tires prob nothing fnacy just something nice and light and a tire with decent tread. And for a bit more speed I want something easy so itll be an air filter, and somehing else but Im not sure whats out there anyone know of a pipe or a bit larger bore?
    Rides
    200es Big Red "Ol Bessy"- Hondaline front rack
    2005 Honda 650 Rincon 27 inch ITP Muds with 14 inch C Series Wheel, one inch Bigfoot lift kit, 2500 Warn Winch, 60 Inch Moose Plow, Hondaline Front and Rear Camo Utility Bags, K and N Filter
    1999 Chevy silverado V8, K and N, fiberglass bed cap, mossy oak accents, hypertech computer tuner.
    Dec 2005
    lake villa il
    104
    free stuff rules now lets see some
    Baltimore, MD
    6,088
    If it has a hi-low box, 110 or 125m.
    May 2005
    Dorset United Kingdom
    1,408
    I think its probably a 200es by the sounds of it..... is it chain or shaft drive?
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Sep 2003
    Brookville,PA
    1,408
    With the high, low, and reverse. Sounds like a 1984 Big Red.
    Jun 2004
    Indiana
    196
    Thanks i was thinkn the 200 as well. I am a big boy and a 125 mighta been little bit small. I just called em I pick it up in a week or two whenever i get time off from rugby practice. So its a 200es does anyone have the performance suggestions
    *Edit* But yes i will get picsas soon as i pick it up
    Rides
    springville, PA
    6,185
    if its shaft it a 200es. If not its a 200e. get a high comp pistion, thats about as good as anything
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jun 2002
    Mississippi
    2,552
    performance? not on that. nice ride but it aint a racer
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Jun 2004
    Indiana
    196
    Not wanting it to be just a bit more power, this is argued all the time so I am not wanting to have a racer. I just want to go through the trails and on the straightaways faster. So Air filter, Pipe, Cam, and Bigger bore are my options right? Does anyone have any company names or parts you are selling.
    Rides
    springville, PA
    6,185
    Check dennis kirk for exhaust (if there is even an aftermarket one), webcamshafts,com for a cam, and get a K&N filter. Boring really doesnt help proformance but a 10.25:1 comp pistion will make you have much more punch. and maybe some smaller tires on the back. Good luck if your doing this to a 200es.
    Nate
    R.I.P HRR
    Jun 2004
    Indiana
    196
    Well heres my options from DK. Cobra Utility Series, Cobra Quiet Series, and Cobra Megaphone. Not a fan of cobra because Ive heard of the rusting, who has experience with cobra's performance and its rust problems. Moose, KandN, and Uni filter. A 67mm bore Piston (thats the highest if its a realy big jump from stock ill go a step or two lower). Or a newer carb. I want to mix and match two or three. Airfilter is in becuase its the least expensive. This trick doesnt have to be balls out fast just some easy add ons for more power on the trails and not kill motor life.
    Rides
