Results 1 to 15 of 16
Thread: More questions on 85 250R
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    I have a few more questions on 85 250R for the pros here.
    I went to change all fluids and were all spotless from grime, rust, crud.
    (Real clean gear fluid and coolant)
    Someone obliviously went to effort to keep this machine maintained hence is why it probably runs pretty good.
    Now, the oil mix sticker says 20:1. I want to run Maxima 929 castor.
    Should I keep this ratio 20:1 per manufacture recommendations?
    At 20:1 that comes out to 32 oz (quart) of oil to 5 gallons of gas?
    Also being this is a stock machine, what octane is good to use?
    I think manufacture says 92 minimum. Our pumps up here will pump 85, 89, 92fuel. I am at 5000 ft.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Aug 2002
    New York
    1,098
    1 can of oil to 5 gallons.
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    well because the sticker says 20:1 back then they were probly using motor oil but now that we have all these fancy oils for 2strokes to choose from. with the castor 926 i use to run 32:1 and that is 8oz to one gallon and 40oz to 5gallons. with the newer stuff you can run a little leaner and the oil is better for you engine. hope that helps.
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by ChrisD
    Ok got a liter of of 927. dump the whole liter in with 5 gallons of gas and go from there?
    Liter comes out pretty close to 33 oz i think.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    May 2005
    Dorset United Kingdom
    1,408
    You dont want to be running anywhere near 20:1 with a modern, good oil.
    I would think either 32:1 or 50:1 would be better. If you run it at 20:1 you will have a fogger!! Trust me on that one
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by slothminx
    Haha. LOL, Fogger!
    I will try 32:1 first!
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    Quote Originally Posted by breastman569
    isnt 32:1 4 oz of oil to 1 gallon of gas?
    crackshot's Avatar
    Idaho
    1,024
    yep. according to my calculations it is 4oz to 1 gallon at 32:1
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    wanta86r's Avatar
    Nov 2004
    mn
    385
    i think you need to work on your math man.
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    Order a ratio rite from Dennis kirk or your local motorcycle place,they usually have them.Its a measuring cup for oil and has the markings for the amount of oil to add to make whatever ratio you want.Whatever oil ratio you use check the plug after riding for a while for the right color,it needs to be tan.It will take a little riding on a new plug to read it good,unless its really rich.
    crackshot's Avatar
    Idaho
    1,024
    Quote Originally Posted by wanta86r
    Breastman might have typed wrong thing. No biggie.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    wanta86r's Avatar
    Nov 2004
    mn
    385
    i was just giving him a hard time.
    crackshot's Avatar
    Idaho
    1,024
    Thought so!
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Feb 2005
    272
    haha oh man my bad sorry about that, thats more along the lines of 36 or 38:1
    Aug 2004
    Ab Canada
    4,368
    50:1 Amsoil!! 927 Can rust your Cyl...so a little birdie told me..
    1985 Tri-Z-
