Results 1 to 7 of 7
Thread: ???????????????????????
    May 2005
    Edson Alberta
    15
    Hi i have a few questions
    How hard is it to change a front and back sprocket on a 1983 Big Red 200E with the high/low Tranny? Also my axle is all loose? is there Axle bearings in their or what? where can i find these parts and also how long does it take to completely take apart the trike to the frame? And how long does it take to change the sprockets and bearing
    Thanks alot
    Mike
    Edit - Just found rear bearings do i need 1 or 2?
    Also will any other ATC Rear Fender Fit on my Big Red? like a 185 M Rear Fender>????????????? or 200x?
    1983 Honda Big Red 200 E - 1st Winter Project
    1973 Honda CT 70 - 2nd Winter Project
    ???? Honda ST 90 3rd Winter Project
    May 2005
    Edson Alberta
    15
    I need to know about the bearings i am pretty sure its 2 correct me if i am wrong?
    Mike
    Nov 2002
    Kirkville, NY
    3,831
    You need 2 bearings and 2 seals (one for each side of the bearing carrier). If you edit your title so that people would know what you are asking you would get more responses.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jun 2003
    South of Rochester, NY
    3,470
    I think your only other rear fender option would be a 200M. However, seems like a local place here in NY has both rear fenders for a Big Red/200M. Not sure how much he wants for them.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    bruce there 35$ each with mud flaps no cracks little spray paint on them not mutch though.
    leroy, new york
    1,025
    Bearings are less than 25 with seals to replace easy as hell to replace and worth it. And replace the sprokets and chains together, because they ware in a pattern.
    May 2005
    Edson Alberta
    15
    Thanks alot guys that helped alot! to get to the bearings you need the rear sprocket off right? to take the other side of the chain guard off and un screw the bolts and walla?
    also with the front sprocket do you have to take out the tranny?
    thanks
    mike
