Results 1 to 15 of 53
Thread: tri moto125 questions
    CT
    40
    i just picked up a 83-85 tri moto 125 today for $100. its in pretty good shape, it was sitting for 3 years and still started up w/ no choke on the 2nd pull. it needs a few little things tho, i need a choke cable but cant seem to find one anywhere, are there any good sites out there for parts on this bike? also i need the seat latch. thanks a lot if someone can pint me in the right direction.
    i was also pretty much just lookin for anything i should kno bout it like what kind of gear oil and the such
    i took a quick shot of it when i just got home
    ill put up a few more when i get some tires on it and clean it up a little bit
    [IMG][/IMG]
    kando is offline At The Back Of The Pack Arm chair racerFirst time rider
    Saskatchewan
    212
    Yamaha stills has choke cable for around $40, The seat latch you can get at a motorcycle wrecker. Your trike looks to be in fairly good shape, I've seen alot worse, good luck.
    1982 YT 125 Yamaha 1984 Honda 200 m
    Feb 2005
    Canada
    663
    I own a 175, lots of fun.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Oct 2005
    Pennsylvania
    863
    Do you have the choke cable?---Is it missing or broken?---If its frozen---your in luck---Coil it up and dump it in a bucket of kerosene for a day or two----good as new----otherwise --any small piece of bicycle brake cable will do----Dont spend a ton of cash just yet---As far as starting with no choke after sitting---it has to be sooooooooo rich for that to happen--and carbs on those machines are very picky-so make sure it runs well before spending the cash . Ingenuity and a few bucks -may save you a load of money down the road.---That appears to be an 82--Look at the vin---Is it 5V6-.............?
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Oct 2005
    Pennsylvania
    863
    Damn ---Where are my manners---
    to the boards-
    Those little trikes are a blast-------Enjoy!
    CT
    40
    i havnt realy looked the machine over to well yet, i just picked it up around 8:30 last night. i do have the choke cable, so i guess ill be picking up some kerosene on my way home from work.
    thanks for the tips guys
    CT
    40
    i took a look at the VIN tonight, it does say 5v6.. that means it an 82?
    im also looking into some tires right now, i want something for mud/snow. i saw the
    cheng shin mud busters. are they a decent tire?
    Oct 2005
    North Branch, MI
    196
    bikebandit.com should help you with some parts you need. if all else fails about your choke cable, a sure redneck solution is a dime size hole drilled into the back of the airbox for some good ol' ether.
    Oct 2005
    Pennsylvania
    863
    1982 Yt125-j
    CT
    40
    what does that "j" mean? i was lookin on bikebandit.com and some parts were for a j, or a h, or a g.. i was curious to what that ment
    Oct 2005
    Pennsylvania
    863
    G=1980
    H=1981
    I=looks to much like a 1 so it wasnt used
    J=1982
    K=1983
    etc-etc-etc
    The 5v6 is the markings used on an 82 yt 125-- J for 1982------The YT175 from the same year used 5V7----
    CT
    40
    thanks, i was curious as to what that ment. i ordered some rims and tires on monday, and cleaned up the plastics today, so as soon as its all back together ill throw some pictures up
    Aug 2004
    Ab Canada
    4,368
    Wouldnt the kerosean Eat the rubber coating on the cable?
    1985 Tri-Z-
    I have my 1982 yama 125j on ebay right now in parts ,had a,lot of good parts on it and was semi restored when the crank seal blew,but when i did have it running it was a fun lil trike if ya need any parts hit me up.
    1983 Honda 110
    1967 Mustang
    Oct 2005
    Pennsylvania
    863
    Quote Originally Posted by My trike Sucks
    After 3 months -Yes---overnight or two---Not a chance--
    Just long enuff to penetrate the casing
