Results 1 to 10 of 10
Thread: Alternate 83-85 200x forks?
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Are there any other forks that'll fit on the 83-85 200x's? One of my fork tubes just got a crack near the bottom from something, looks like a piece chipped off from hitting a rock or something, not sure when that happened though. Anyway, it's slowly leaking oil now every time I go up to the garage there is a liitle puddle of oil on the ground beneath it. So I want to know if 86-87 200x or any year 250r forks will fit. I know 350x forks do but do you have to do any modifications? I really don't want to have to buy another set of tripples or a different axle or brake caliper or anything like that, just the forks themselves. Any help would be great, thanks.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    I think you should be able to find forks for a 83-85 200x faster and more inexpensive than any of the other bikes you have listed above. As far as fit, I think they all are the same diameter so you can use them all as far as the triples, as for changing the axle and what not, just make sure the brake disc is on the correct side, I know the 350x and later model 250r's had the brake disc on the opposite side than your 83-85 200x.
    Howdy's Avatar
    Celina, Ohio
    10,079
    250r & 350x forks are NOT the same as a 83-85 200x. To use them on a 200x you would be required to change ALOT more parts than just the forks. In fact you would have start with the tripple tree and would end with the wheel / axle.
    83-85 200x forks can be found just about any day of the week. I have a set of silver and a set of Black sitting on the shelf. I know others have sets kicking around as well.
    Howdy
    Aug 2005
    Lancaster, PA
    316
    It's just that I want better forks, I know that I can easily get 83-85 200x forks but they're weak. So forget about the 350x or 250r, what about the 86-87 200x forks, I've heard those are better then the 83-85 ones...is that true? Will they fit? Thanks.
    Trikes
    Bikes
    Jan 2005
    Great Bend
    704
    well the 86-7 200X forks are the same size as the 83-5 200X forks. as for being better, I dont know. get you another set of 200X forks and rebuild them with new seals and swipers, add a set of progressive rate springs and maybe a set of 1" spacers in the forks to add stiffness. put a heavier weight fork oil in and you should have a nice set of forks to put on.
    putting on "technically" better forks wont do a bit of good if they are not set up right.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Aug 2005
    Lancaster, PA
    316
    Quote Originally Posted by ATCWRENCH
    Yeh I understand that, it's just that a used pair of forks that are already stiffer are cheaper then buying the progressive springs and whatnot. Anyway, I'll see what happens, thanks for the help.
    Trikes
    Bikes
    Lancaster, PA
    1,738
    If I remember right, you can use 250r forks but you have to use the 250r tripple tree and press out the headset tube and use one from the 200x. I think thats right.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Jun 2003
    englishtown NJ
    2,676
    I used a 350x tripple in mine 86 200x with a 84r front end.
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    If memory serves.....
    Back in the day the racers used to run 83/84 250R forks on their 83-85 200X.
    Triples need to be bored minimally as the tubes are 35mm vs 33mm.
    More travel was the result.
    Curtis
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Apr 2003
    HARTFORD CT, USA
    478
    I agree
    83-84 250r forks should work now go find a pair..
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
