can i just pull the cable off my thumb throttle and put it into my twist? i have a stock thumb throttle and a motion pro twist throttle. i have never tried swapping them before so i figured i would ask before i go diving in there.
Im pretty sure, but listen to other people to. I dont want to be wrong.
1985 Yamaha 200E Shaft - New Toy / Project
1983 Yamaha YT175 - Kinda retired?
I do beleive it's just that simple !!! As long as the mounting screws are not seized on !! ( that tends to happen alot with 20 year old machines !! )
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
I don't think you can I believe most twist throttles need a longer cable then the Thumb throttle, at least all the ones I messed with.
1985 Tiger 250LC
1985 Tiger 200LC
1985 ATC 350X
1985 ATC 200x
1973 ATC 70 (resto project)
and many more!!!
Blue Line Graphics
Yes, it is that simple! Did it with mine. Only took about 10 minutes. But im going back to thumb. Right turns are a killer w/ twist on a trike.![]()
mine on my 200x, I had to use a 83-85 twist kit for the 27mm carb I have on my 86 200x. most require a different cable. I like a twist better, but I wouldn't put one on my 250r, way too fast of a bike and a small slip will send me flying off the back, my 250r is far from stock.
I had to use a longer cable for my 83 250r. Above all, i like the thumb more.
I agree. About 97% of teh time, the twist requires a longer inner cable.Originally Posted by blue27
my thumby is stiff and won't return smoothly. i have cleaned the slide and there are no kinks in the cable and it is routed freely but nothing helps. also i use twisties on all my motorcycles so i feel comfortable with them.
Try lubing the cable ?
