Results 1 to 14 of 14
Thread: 85 vs 86 350x carb
    85 vs 86 350x carb
    I was looking in the specs here on 3ww,it says for the 85 model 350x the carb size is 31mm and for the 86 it is 34mm...is this correct?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    anyone?
    85 Honda 200X
    88 Honda CR 125
    kloby's Avatar
    kloby is offline I have been Busted! Can you say OWNED! At the back of the pack
    Feb 2006
    Oklahoma
    253
    85 = 34mm round side
    86 = i beleive it is 34 mm flat side :
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    the carbs are the same. The 86 has an extra jet. Thats why the 86's start so easy. But the carbs are the same size.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    ok thanks...
    85 Honda 200X
    88 Honda CR 125
    Jul 2004
    Baton Rouge, LA
    946
    Yeah I heard that the '86 and up carbs weren't as cold natured....that's why I put an '86 carb on my 350X..
    1985 Yamaha 225DRN w/OEM headlight guard, footboards, front rack, rear rack, work light, brush guards and trailer hitch
    Jun 2002
    Mississippi
    2,552
    how can i tell the difference? i have a 350x carb that i was going to put on my 300ex but i have no idea what year it is.
    thanks
    chris
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Jul 2004
    Baton Rouge, LA
    946
    The carb should have a serial # on it....that should tell you when it was made perhaps...I think you can look up and see which it is somewhere.
    knsmodels's Avatar
    knsmodels is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Bucks, Pa
    318
    Easiest way to tell them apart is the pilot screws are different
    Carb on right is the 86 design
    thanks for the pic KNS....
    85 Honda 200X
    88 Honda CR 125
    kb200x's Avatar
    Aug 2005
    KY
    295
    i was just kidding about the 86's starting easier. I dont think it helped at all. I ride with OVhonda alot and he has a 85. I cant tell a difference in starting them. I think each trike has there own way they like to be kicked and once you figure out what they want its all good.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    The service manual (Where the 3ww specs come from) is printed incorectly and shows that the carb is 31mm when it is infact a 34mm.
    Old 179's Avatar
    Old 179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Southwest Indiana
    300
    Honda service manual : Id mark: 85 is QA05A and 86 is QA10A : 31mm both and same specs. Dirt Wheels test on the 86 ( Jan. 1986 issue) has it list as a 34mm.
    ATV News had it listed as a 34 also.
    Aug 2002
    NY
    2,652
    so if they are almost the same. does that mean i can buy an 85 rebuild kit for my 86 carb. all the places i looked list them as 85 and not 86?? thanks sorry to ask on your thread.
