Results 1 to 2 of 2
Thread: another KX500 conversion??
    Question another KX500 conversion??
    I guess I'd better just start my own thread..instead of hijacking everyone elses. I did a bigbore, carb and extended swingarm on my 86T3 last year and just want more.... I keep seeing the KX500 threads and it just makes me salivate thinking about the swap. I do have the necessary tools and skills for the job. I have a few questions that I couldn't find answers to in the searches I have done.
    Is there a certain year of KX500 that would be the best donor? As far as motor mounts/dimensions and power? I am assuming some beefing up of the frame will need to be done and a custom pipe will need to be built too, but what frame mods are necessary?
    If I were to decide to do this, I would most likely raise the capital for the 500 by selling my Tecate motor. I have the LA Sleeve 285cc bigbore installed, some portwork has been done, all new bearings were installed prior to bigbore too. I also installed a Airstriker 38mm carb from Sudco. I have a DG( better than nothing) pipe and silencer too. As far as the cosmetics, I painted the sidecases black and then polished out the raised letters on either side. I partially polished the rest of it to clean it up too. I am curious what kind of $$ a Tecate motor like this would bring.
    Oh and what electronics need to be swapped? I am assuming the 250 cdi and related parts won't work with the 500 here.....
    THanks in advance everyone....Todd
    Banshee Killer
    Aug 2004
    Phoenix
    1,229
    89 and up motors are the best to use.
