what should one look for when looking at an 83-85 tecate? any common issues these early tecates have?
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
Don't know of many issues with the first gen T3. Look at the rad hose mounts on the rad to make sure they arent cracked or leaking, check for weak spark and if possible pull the side cover to check the flywheel for up and down movement (crank bearing play), turn the axle to check its straightness. Just basic stuff you'd look at when buying any bike IMO. Nothing stands out in my head as something I'd immediately look at. Just look the bike over carefully and you'll be fine. Don't kick the tires...
A 1985 250R.Originally Posted by sblt500r
Sorry I had to do it.![]()
very nice
Hey there sblt500r, The first thing you need to look for is spark, alot of T-3's had a problem with stator/flywheele's!!!!!! But The good thing is that RICKY STATOR has made a better one and is more reliable! After that yes look for straight axels and swingarms. Also make sure that it's not honda red!!!!!!!!!
It ain't about the money, or even being #1, you gotta know when it's all over you did the best you could of done! And knowing that it's in you and you never let it out, is worse then blowin' any engine or any wreck you'll ever have!
_________________________________
84 Tecate RED with a 310 Big bore!![]()
84 Tecate Red
84 Tecate Green, in pieces(was a parts bike, not anymore!!)
85 TECATE--NICE!
85 350x needs a little tlc
86 350x
86 TRI-Z
check all the mounting tabs on the radiator. stand behind it and look at the bearing carrier mounting tabs. may have to get close but they may be bent to the chain side. check for spongyness in the rear shick.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
yeah i want to get an 85-86 250r. but this guy has been pestering me, and i haven't been able to find a 250r that needs work for a good price. i want to make it mine, ya know! plus i want to get rid of my rm 80 and he wants it.
i'm going to go over the trike good. i was just wondering if there was any problems that were specific to it. and supposably it has a new ignition, and is all original with $1500 invested??
My Feedback
thats one nice looking t-3 you got there.Originally Posted by going4broketecate85
My Feedback
well if you dont know what to look for then grab some pics of it, post them here and we'll pic it apart for you. if it has a new ignition i wouldnt worry too much about anything other then if it needs crank bearings. and those arent hard to change if you know what your at.
I was just kidding. Tecates are good trikes.Originally Posted by sblt500r
Originally Posted by Dammit!
But are they AS GOOD ( Good meaning Reliable ) as a 250r? This may start a whole new war![]()
