Results 1 to 3 of 3
Thread: Do '81-'82 and '83-'84 250R Pipes interchange??????
    Feb 2005
    Orchard Colorado
    659
    Question Do '81-'82 and '83-'84 250R Pipes interchange??????
    I need to know if '81 250R pipes interchange with or will fit on an '83 250R?
    Jan 2005
    Great Bend
    704
    no they will not change out. they might with a little bit of work but its not a direct swap. the 81-2R's had an out of frame pipe while the 83-4R's had an in frame pipe.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    kloby's Avatar
    kloby is offline I have been Busted! Can you say OWNED! At the back of the pack
    Feb 2006
    Oklahoma
    253
    Yeah, just a little modifcation on the frame and it should fit ....
