After looking @ the Honda Repair Manual, how hard is the clutch basket to remove without the puller that the manual makes reference to?Whats the easiest way to remove the entire clutch assembly?
Current Rides:
All Red's!
No puller needed, I think the tool the manual talks about is a Clutch basket holder. This is used to hold the clutch while you break the nut loose. I just use a Impact and have NEVER had a problem.
Howdy
Thats what i do![]()
Originally Posted by Howdy
I figured it would be easy.![]()
Do you know what size mm the nut is? I just had the cover off a while back and wish I had changed out the clutch then.
Current Rides:
All Red's!
