what would you need to do to put a honda 250 axle with the sproket on the right side into a yamaha 200 frame? and how hard would it be?
your first delima will bearing alignment, then your second would be chain alignment.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
anything afer that? chain wont be too hard, but bearings, i can chop my frame to make it fit? would that work? sorry im a noob at this stuff
I've never seen the back of a yamaha 200, but you might beable to fab something up to hold a 250R bearing carrier. that will solve the bearing alignment issue.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
2+2 axle NOS NASA
18x10x9 Hoosiers
Why dont you just get a Yamaha 200 axle? It would probably a lot cheaper, or are you looking for better wheel choices?
i need to get n axle with the sprocket on the oppisite side of wat its on, becuz im puttin on a new motor and its on the oppisite side, and i dont kno if its possible to switch the brake and a the sprocket from the place its in..
if it is possible to switch the sides the sprocket is on then let me kno, but i can get a 250R axle from a friend that doesnt have anything from the bike other then the axle, so hes goin sell it to me for cheap,
81 yamaha restore project
83 Big Red(piece of trailprotrailprotrailprotrailpro)
can anyone help me here, i need as much info as possible before i start this project!!
hmm,sounds a little crazy.i say just restore it,and enjoy it.don't mutalate the poor trike.buy a quad for that!!!!!!!!!!!!!!
i would but i got this trike free, and i can get a 250R motor REALLY cheap..so..ya..lol i wanna put that in it
Sounds like you are re-inventing the wheel. I suggest selling the parts you have, and then buy what it is you want.
no one around here would buy the parts, there all in bad condition, i just want to kno how i could get the 250R axle in my yamaha or change the side the sprocket is on..
or how would that 250r axle bolt into a honda 200m frame? and how would a 20r motor fit?
i think you'll just end up with more problems than its worth. just my opinion.![]()
