i would recomend taking it to a shop and have them check it for what bore size you need. then they can order the rite piston and do the bore it out for you.
it would suck to not be checking it rite and order the wrong size piston.
the 85 and 86 250r's can go to .120 over. the 87-89's can only go to .080 over . you can bore them to the .120 over if you use the old style pistin and get a spacer plate. making a spacer plate motor make a noticable difference.
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
