Results 1 to 11 of 11
Thread: will a 1984 xr250 carb fit a 200x????? reply!!!!
    crd00's Avatar
    crd00 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2006
    somewhere over the rainbow
    323
    Exclamation will a 1984 xr250 carb fit a 200x????? reply!!!!
    Will a 1984 xr250 carb fit my 1983 200x? because i need a 200x carb or something else that will fit it
    get a xr200 carb,,,,
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    crd00's Avatar
    Feb 2006
    323
    Question
    ya i know i can do that but i want to know if a xr250 carb will fit because i can get one
    if you can get one cheap then I would say try it...but I have never really looked into it....
    85 Honda 200X
    88 Honda CR 125
    kloby's Avatar
    kloby is offline I have been Busted! Can you say OWNED! At the back of the pack
    Feb 2006
    Oklahoma
    253
    There is no reason it wouldn't fit. I say go for it if thats the carb you wanna use.
    crd00's Avatar
    Feb 2006
    323
    thnx for your replies anyone else? because i need some more opinions
    Aug 2005
    HI
    1,575
    Kloby...come on now. The reason the carb woudn't fit would be the intake. Now i am not to sure if it will fit or not, but if you have one lying around, then pop it on and see if it will work. If you do this mod, you will have to use a clamp on filter, and/or make a new piece to go from the airbox to the carb. Do you have a pipe or any extensive modifications to your 200x? If not, there is no reason to do this.
    Rest in peace Rex Carlson
    crd00's Avatar
    Feb 2006
    323
    no its just that my 200x has a 200m carb in it with 200x jets and im looking for another carb that will fit because the 200m carb takes ALOT of power away from it and i know where to get a xr250 carb
    Aug 2005
    HI
    1,575
    This will still more or less hurt the bike rather than help it. This will richen your air mixture and fuel mixture to much. To my knowledge...a 200m carb is 22mm while a 200x is 24mm. A XR200 carb is 26mm so I am guessing the 250 carb is in the range of 27-30mm. That is HUGE for a stock 200x. I would not get the XR250 carb unless you are wiling to go a gigantic big bore. I run a 198cc big bore and only use the XR200 carb. Search on ebay for a 200x carb. It will be perfect for your trike.
    crd00's Avatar
    Feb 2006
    323
    ok thnk you very much for your reply
    jmack3986's Avatar
    jmack3986 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Lancaster, Ohio
    447
    depends on mm size stock 200x is a 24 you can put on a 24-28 mm carb. but you will have to do alot of jetting to get it precise.
